i always find tripminders give me a few weeks so i can check my yards.
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!! 1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.
yes you do if you get one from matt make sure you get a harness it will be useless without the harness i have one from a 89 but the harness is different cause 1 year only harness
One jumper ground wire is needed on the newer cars at the conector that plugs in the back of the tripminder. I think there is an extra one somewere in my shop. My GM is an 87 with a 90ish tripminder. Notice the black wire in 2nd spot is just single in the old harness. I added a wire to it and jumped it to the 4th spot which is how the newer harness is set up. Old harness used for a newer unit.
[ATTACH=CONFIG]30061[/ATTACH]
Y
es, if you're using a harness from an '85 or older (CFI or carbed models), you will run into this issue. I have the proper harness for you with the jumper already there
Is the case just to secure it in place?Will it work without the case?If the tripminder will work without the case,I am interested.How much were thinking price wise?
