lOOKING FOR BODY MOUNTS FOR LINCOLN TOWN CAR 1989.
Body mounts / town car 89
as ridiculous as it sounds, that's probably your only choice. There is a universal kit somewhere out there, too. Either way, you need to shim it and shape it custom. They don't make new body mounts anymore.
there is no known source for direct fit ones. Somewhere on here there is info on the polyurathane bushing kit and the adapter washers you need in order to allow them to work properly. I have new poly mounts on my car with the adapter washers and it works quite well. I'm gonna warn you ahead of time, start spraying the bolts with some sort of penetrating lube a while ahead of when you plan to actually do the job. Those bolts *suck* when they break off somewhere. I had to get access to 3 of mine, 2 broke and one nut broke loose of it's retainer clip. Not fun.86 Lincoln Town Car (Galactica).
