1997 GM Holy Grail, just under 23,000 miles, $7,900
    Just add trans cooler & hitch and tow 5,000 lbs...
    https://www.boutiquemotorsinc.com/ve...hills-il.shtml
Name:	1997 Holy Grail Grand Marquis.jpg
    Good luck!
    Nice LS trim HPP. Definitely needs the rear exhaust hanger rubber replaced, the tailpipes shouldn't be drooping down like that. Coolant reservoir looks like it has brown fluid in it, that should definitely be green. Always seems to be a hard toss up on low mileage older cars, either they're super original and likely have a bunch of very old consumables or components not favorable to non-use that should have been changed (fluids, tires, seals) or they've been cared for on a regular interval thanks to a persnickety owner that kept things A1.
    Build sheet is interesting. That car was built seven days after mine was in 1997.
    My Cars:
      Where does one get a buildsheet like that?
      I like HPP Aeros.
        Ford's OASIS information system for service technicians, which provides historical data and other resources, based upon VIN.
        Good luck!
