eBay item # 184381168745 is Ford part number E0LF-9275-KA, a fuel gauge sending unit which very much looks to be correct for box Panthers, and has the carburetor fuel pick-up tube. It also has a second tube, the function of which I am not sure, since I thought all the carb Panthers were returnless...but it seems I am mistaken about this.
Listing says it's for 1980 Lincoln Panthers but I suspect it could be usable (plugging the second line fitting where not needed) for:
79-89 Ford/Mercury with carb
80-87 all Lincoln with carb, 88-89 Lincoln only with analog cluster and carb (if they even exist that late with carbs)
As I do have a carb Panther I'm very tempted by this but the price is just a little high for me...I have two, both in poor condition, which is why I'm on the fence about it. But hey, figured I'd throw it out here in case someone can use it. It's a rare item, especially with the second line fitting.
Edit: WARNING: This thread and things I've said imply things that are not true! Lincolns with digital clusters use different senders and these different senders have the wrong resistance for Ford/Mercury/analog Lincoln. Tread carefully.
