Moog K8600 upper ball joints ('92-'94) on wholesaler close out at Rock Auto
1985 Ford F-150 XLT Lariat
1966 Mustang coupe (restoration in-progress)Tags: None
Unless I'm mistaken, that's the "old design" that was "superseded" by the newer ones, right?
It doesn't cross to 95-02 cars but it obviously will work, since one can use the 92-94 arms with the 95+ ball joints.
Buying a hideous quantity of these. Thanks for the heads up! I don't have any 92-94 cars in my vehicle list so I never would have seen these, I normally shop by 96 or 01 for those parts.
yeah you can use 92-94 on 95-02 but you need one left and one right. The later design used the same part number for both sides.
I might throw a pair of those on the shelf just for spares. Its what I run on my car.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyeah you can use 92-94 on 95-02 but you need one left and one right. The later design used the same part number for both sides.
When I did my '91, I used the part for 95-02 (I would have bought based on a 2001 application). There was no description of left vs right, same part spec'd for both sides. However, you can clearly see looking at the part that it curves in a particular direction, as if it should be throwing the caster positive on one side, and negative on the other. It looks like a side-specific part, but it seems to have enough range of adjustment to make up for it since it aligned OK...
Greaseable... may order a pair myself.
Originally posted by sly View PostGreaseable... may order a pair myself.
I ordered 6. 2 for wagon, 2 for Lincoln, 2 for 2dr. 91 is already wearing Problem Solvers purchased for 50 bucks a pop.
Originally posted by kishy View PostYes...if it is the actual Problem Solver part like it says, in private label packaging (my past experience says to bet on it being a CarQuest branded box that's as old as time), it's a killer deal.
One wholesaler close out I did a few years ago was some Motorcraft FL300S filters for my '95 Cobra. I ended up receiving a bunch of filters that looked like they had been made in the '70s. They worked fine, though. I only have one left.—John
—John
yep, old good ones.86 Lincoln Town Car (Galactica).
For box folk, the TRW 10334 upper ball joint is on closeout for $8.08 and the TRW 18845 pitman arm is going for $8.6186 Lincoln Town Car (Galactica).
The experts have spoken. Looks like it was worth it! Thanks!—John
I got 1.75 of them today. One was "missing" the grease boot. Rather the boot was in about 30 pieces. Already got RA to send another. Hopefully I get a black boot and not the blue one.
I ordered a pair and some other things too. Nothing like going to spend 10 bucks and checking out for 75. I have a pitman arm and a pair of Permadry valve cover gaskets on the way. Didn't need the gaskets exactly but you don't find them for 13 bucks very often.86 Lincoln Town Car (Galactica).
