My Rare and Interesting Findings.
My 82 had that indicator in it. I thought it was odd when I got in a newer one and saw Drive instead of 3.1990 Country Squire - under restoration
80-89 NOS FORD LTD CROWN VIC E3AZ-54405A26-A FUEL GAS DOOR
Anyone need a factory trans cooler bracket setup for cheap? Says 92-94 LTC but I bet it would work on any aero and probably could be fit to a box with small effort.
Didn't someone need quarter window trim for a 2dr. ?
https://www.ebay.com/itm/176165710957?_trkparms=amclksrc%3DITM%26aid%3D1110 018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26as c%3D280573%26meid%3D5b2808e61d00451f80ac379a27b475 01%26pid%3D101196%26rk%3D3%26rkt%3D12%26sd%3D14564 5542164%26itm%3D176165710957%26pmt%3D1%26noa%3D0%2 6pg%3D2332490%26algv%3DCompVIDesktopATF2V6ReplaceK nnV4WithVectorDbNsOptHotPlRecall%26brand%3DFord&_t rksid=p2332490.c101196.m2219&itmprp=cksum%3A176165 7109575b2808e61d00451f80ac379a27b47501%7Cenc%3AAQA JAAABIB1CtWCYZXLUOT%252FaKfSD9L5PxxQ4G1PC8Iy4FNTqf nE5LB1rMzkoAxxG4NMVtP9V1QgpWUKDYzm%252BykbPCCdeMdV uINKOPROfusqH4w82Q8%252F4nSTcsEv2YiBTwc2VB4JxUMxsD ldbz4sMq1YKn3pXkdGh6UnYPsH33M6yYQtO0ECFlzQvOmW1bey BHmGDU6rFM9O4fHX%252F6SVg%252BG%252FuB1oF26BgNqHae rlownbt6SnVKaSYXEeJ5vnIrv0Ekc%252FD7onlzjAO0DW8t2% 252F49NIQ56kJuxWiIsNC8Oqg70c6tmnLpZCSCHn6JbmHSVPbw tedYakFV%252Bw13soQ%252FL2j%252F9fImePlbBMz3EKiEOZ F12CnGgd%252BOyD%252BGBMgrWAPwpcrfz9JtOc78g%253D%2 53D%7Campid%3APL_CLK%7Cclp%3A2332490&itmmeta=01JKN Y5YGDYAT4DFEXCKBHEZXR
90 Colony Park
70 HEMI Daytona Convertible
for the part... not the shipping... but that's a pretty rough spot on it. Looks like someone hooked a bungee to hold the hood down or something and beat the hell out of that spot. Definitely a only use if yours is broken part.
I see a bunch of these new fuel pump sending units on eBay. I’m sure it’s too good to be true but thought I’d post it here in case someone wants to try one. I might. It says it fits 82-89 but I know there was a difference between the carb and efi years.
Features: Drive Type:Mechanical Fuel Type:Gasoline Part Type:Fuel Sending Unit Items Included:Mounting Hardware Placement on Vehicle:Fuel Tank Type:Fuel Sending Unit Please confirm your car model is as same as the picture before submitting your order Fitment: For 1980-1983 Lincoln Mark VI 5.0L For 1982-1989 Mercury Grand Marquis 5.0L For 1982-1989 Lincoln Town Car 5.0L Package : 1* Gas Tank Sending Unit W/o Product Instruction Notes: -If You Are Not Sure The Item 100% Fit For Your Vehicle Before Your Purchase. .
