Originally posted by 87gtVIC
View Post
My Rare and Interesting Findings.
Originally posted by mcb82gt View Post
Is that the correct piece for a 86 MGM drivers side?Originally posted by Arquemann View Post
Nope, CV only. Look a bit closer and you see its not the same at all.
It does not fit the Mercury; although it does look similar to the Mercury turn signal it is substantially different.
mcb if you're hurting for an 87-and-below turn signal, I believe I now have several in storage, so shoot me a message if you're not having any luck closer to home.
- Likes 1
Originally posted by 87gtVIC View PostNos 1979 Ford LTD Steering Wheel D9AZ-3600-K
Keep in mind spline type if considering this wheel. I recall some kinda difference between the early and late years.
https://www.ebay.com/itm/305701091855?itmmeta=01J4E4QN21ZWZ5Z51WNYEEN3WD&am p;hash=item472d347a0f:g:KWkAAOSwXDlmqP2r&itmpr p=enc%3AAQAJAAAAwGG6rmkp7gQpIYcb3%2Bsr1hIT7ZtxDyxr si--tHzmsITsnY6Mcem5rFMVUtlScqA%2Baq%2FHajrzjxTypcxcnv 2jorH40sf9%2BDw7fS4pm%2FXPjfId5ApAlorfj62JDxSBsZs2 BM5fs5a2mLU0Iw1tDWye2ZGQhVD6mn2o2gDcMk02Udi1TZeQMX XwDkv9x2aWM0zdO8PzLX9Id%2BEGjfRU38hkvxkyajJA347KMs RwAG2Xuh5H77OeR3U3Fa5%2F2pGkrDxPcA%3D%3D%7Ctkp%3AB k9SR6LR3sSjZA
Early steering column parts diagram or shaft separation advice? - GrandMarq.NET - Panther Headquarters
Box Panther Steering Wheel/Shaft Interchange - GrandMarq.NET - Panther HeadquartersVic
hope you don't mind me slightly hijacking, but this is a rare one. 8 track player with the digital tuner
never seen one of those before.86 Lincoln Town Car (Galactica).
What a weird one. Wasn't aware the 83/87ish radio chassis had an 8 track option.1990 Country Squire - under restoration
That is pretty cool. Half tempted…..~David~
