Originally posted by Mainemantom
View Post
My Rare and Interesting Findings.
Having installed a couple sets of them, I'd vastly prefer if an option for our cars existed that attached externally. The in-channel ones create weird water entry problems and require disturbing the window channel, which typically necessitates replacing it at the same time, and the universal channel cooperates even poorer with the in-channel visors than the OEM design channels do.
Originally posted by 87gtVIC View PostTwo FORD E8AZ-10718-A BRACKET NEW IN BOX
Center bar offset like that...Havent seen that before myself. Usually what I have seen was dead center.
https://www.ebay.com/itm/17587384118...Bk9SR7j2mu_FYg
I could be wrong but I have had them before. One style was for HD batteries if I remember correctly which I might not.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
The Scab had (still has? I'll have to look) a bracket with the tall rad mount. PO had a spacer that was whatever was laying around and obviously not stock to make that mount work (it still fit under the hood). I was thinking the same that the rad mount looked extra tall in that pic but also same thought on the E8AZ PN.
Edit: looking back through the RR thread, it looks like I swapped a proper sized stock battery hold down in at some point.Last edited by VicCrownVic; 08-26-2023, 11:12 PM.Vic
Shipping is killing a lot of eBay purchases for me. Many items are pushing $15-$20 for shipping. If the item is $5, that doesn't make sense for me and the seller essentially goes in the hole after fees.1990 Country Squire - under restoration
1983 1984 1985 1986 1987 Ford LTD Crown Victoria Dash Emblem
I was looking for one of these a couple years back. Found one for not a crazy price...also used. This one is optimistic/living in fantasy land.
1983 - 1987 Ford LTD Crown Victoria dash emblem. Has wear seen on photos.
Need it fast? Don't Buy. There is a 2-day handling time. NO EXCEPTIONS
***Priced Accordingly*** You will receive what is pictured only. Don't assume you'll be receiving more than what is pictured. Sounds obvious, but there are those buyers out there... Also, please don't ask if it'll fit your car. Ask your local dealership or do your own homework as we don't have a system that will generate that info.
