My most recent purchase, 2001 cv, old dot car, 93,000 miles.
has an issue with a long crank after about 2 hours (shorted time I tried) where it won't start on first crank, the day before it got ran low on gas(not by me) and the first 2 starts that day didn't do the long crank, it does seem down on power( tho I wasn't get to into it) is there a way to test the regulator?
2001 crown vic
The check valve in the fuel pump maybe picked up some crud, causing the long crank times. I think I’d just drive it if you can get it start eventually, maybe some fuel system cleaner and Hope it clears out. Change the fuel filter after that tank is gone.
On the doors, the Merc doors should bolt on. The trim is different. The mercs usually got a giant hunk of plastic trim. I think the doors are the same minus any holes for mounting the trim. A body shop can make them work.1990 Country Squire - under restoration
Search car-part.com for the doors. I'd bet you can find a set without having to deal with the extra holes from the Merc doors. Might even be able to find the same color if you're lucky.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
ever checked the fuel filter? Might have sucked up some trash and plugged the filter.86 Lincoln Town Car (Galactica).
Originally posted by FordMan77 View PostSearch car-part.com for the doors. I'd bet you can find a set without having to deal with the extra holes from the Merc doors. Might even be able to find the same color if you're lucky.
With the later cars I'm pretty sure you fix it with a tuner, not the speedo gear. It uses engine rpm and the VSS to determine shift points and if the PCM doesn't know what gears are in there it gets stupid about things.86 Lincoln Town Car (Galactica).
2001 uses a VSS gear; no tuner required.
My Cars:
