1985 colony park in uk, fuel filler remote stopped working
    Hi again from the uk, Hope starting a new thread on this is the right thing to do!!!
    My 85 wagon has been great, with only £200 spent in the past 5000 miles! It's just gone round the clock now.
    My glove box fuel cap button has been a bit hit and miss for a while, now stopped altogether. The emergency pull cable in the back is working fine.
    I have taken the trim out the back and can feel the cable going to the fuel cover. What goes on in between I dont know!!
    You guys have always come through for me, anyone had this issue before??
    Many thanks, Melvin
    Could be your switch. Can always try jumping the fuel release door local to the solenoid with some power to see if it works reliably there.
    You can test the switch with a multimeter.
    I installed a fuel door popper in my Vic years back. Not much to it. Single white wire back to the solenoid If memory serves me right.
      +1 on the switch. 84 Continental had the same issue. Jump the wires together and see if it pops. I was able to take apart the switch and polish up the contacts inside. I don't remember exactly how it comes apart, other than it wasn't hard and its not real complex in there. Two brass "fingers", a spring, and a metal piece that pushes down between them to complete the circuit if I remember right. Basically I just pulled it all apart, cleaned the ancient grease out, put a dab of fresh spark plug grease in and put it back together.
        Thanks guys, you got it right again, pulled apart the switch, cleaned contacts, I just had to pack out the back of the plastic button as well to get it firing every time.
        What I really like about my wagon is everything has always been a straight forward fix. (with your help as well)
