Originally posted by His Royal Ghostliness
View Post
Think this belongs here. Removing engine 86 vic
It usually is. But, now you know how to do things. Or, in some cases, how NOT to do things. Either way now that you're familiar with how everything goes together, the reinstall of the new engine should go much smoother. Piece of advice, get yourself a pair of long prybars, one perfectly straight from tip to handle and the other with a curved business end - they will greatly aid you in lining the motor mount brackets back into position once you have the engine and the trans bolted back together. A heavy mallet will also help, or if your prybars are "hammerable" (handles have steel caps you can beat on) you can go straight for the 3lbs engineer's hammer.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Had a friend help me put in it. Things got not in my favor real fuckin' quick. Torque converter studs are not aligned. A fucking thing I wanted to set up before dropping in th engine. Now the engine is on its mounts, and I can't turn the flywheel at all or anything.
What the fuck do I do I am so tired of this constant stream of bullshit.
A good example here of why you don't wanna get into vehicle work that your not ready for.
Separate the trans from the engine slightly in the car, just enough that the flywheel can move without binding on the torque converter. Use a socket on the end of a ratchet and extension, to turn the crank pulley bolt, turning the engine and flywheel over until the holes on the flywheel line up with the studs on the torque converter. Push the engine and trans back together, and bolt the whole mess back together. It's a good idea to use locktite on the flywheel to torque converter nuts as well.
You can turn the flywheel[flexplate]!
The harmonic balancer has a bolt in the center you can use to spin the engine and thus the flywheel[flexplate] to line up with the torque convertor. Over a decade ago when I put the engine in my Fury I made the mistake of not making sure the flexplate matched the torque converter so guess who had to pull the engine again??1985 LTD Crown Victoria - SOLD
Flywheel won't budge. I can stand on a damn breaker bar and it won't move. For the love of god tell me I don't need to pull thus f'ing engine out again. Please give me other options.
All of this god damn bullshit for something that would have taken 4 seconds of work. I knew I should have dove. I brought it fifty god damn times bu.. nope it'll be fine drop it in you can do that after the fact.
Ha ha ha.
Noticed the post before dericks... love how that didn't load up earlierLast edited by DrHax; 06-23-2017, 02:41 PM.
That doesn't make sense... The only experience I have doing that is with Mopar crap. I was able to spin the engine with a breaker bar to line up the holes on the torque convertor.
Did that engine turn by hand/breaker bar before you installed it??? Is it a known good engine?1985 LTD Crown Victoria - SOLD
Couple questions:
Did you leave the transmission in the car? (I am thinking yes)
Did you leave the torque converter in the trans? (I am thinking yes, did you check to be sure it was fully seated into position? Sometimes they slip out a bit)
Did the engine rotate before being installed?
What did you use to keep the old or new engine from rotating while loosening/tightening the torque converter to flexplate bolts?
Take a break if you need to mang, nothing is worse than working angry.1990 Country Squire - weekend cruiser, next project
Its jammed together. You're going to have to pull the trans and engine apart a little bit so it will rotate. This is honestly one of the things that GM did right IMO, they used bolts and all you have to do is spin the converter with your fingers until the holes line up.
The other possible issue is that the converter was not fully seated. If it gets jammed inward without being seated all the way, it can break the pump. Do not force anything. If it won't go, find out why. Otherwise you'll find out why because you had to replace something expensive.86 Lincoln Town Car (Galactica).
Don't do what I did and muscle shit together with a big f'ing breaker bar, turning the converter snout into an egg shape because it wasn't fully seated. Took a new trans pump, converter and a day pissed away dealing with it before the project resumed
'80 Town Coupé
