I joined this forum a while back to sculk about and learn about Panthers as I was considering getting one. Well I did finally get one. I flew to Oklahoma City to pick up a 1991 Mercury Colony Park and drove it home to Northern Indiana the next day (950+ miles). I knew that I was going to love that car when I got home and still felt fresh enough to drive a couple more hours. On the trip home I lost OD due to the notorious TV bushing problem (should have checked it before I left) but seems to have avoided damage as it is working fine after I had my mechanic replace with brass bushing.
It was worth the trip as the car had virtually no rust. A couple of spots on the radiator support where coolant had spilt (had my mechanic clean off and hit with some rustoleum to nip that in the bud). A few other bits of surface rust around the trim and in the inside bottom seam of the door should be easy to put right with out major effort.
Has a few mechanical issues that one would expect from a 23 year old car. I have already got the A/C leaks fixed and refilled as well as brakes. Badly leaking PS pump is next on the list. Cosmetically the worst problem is the totally trashed di-noc. I will probably remove the old and touch up the underlying paint (twilight blue) untill I can scrape up the money to replace it.
Once I get the little niggling things taken care of I will probably look to convert to dual exhaust (2 1/4 inch with H pipe seems appropriate) and possibly some improvement of the torturous induction path taken by the cold air intake. It is already the quickest car I have driven in quite a while but I am looking to maybe improve milage a bit and get a little more vigor in the 50-80 passing range. I am getting 12 or 13 mpg in town and average 19.5mpg at a steady 70 to 75 mph.
Will post more pics in an appropriate forum at a later date.
mike
mike
