zero hour 9am
2nd gen resto
oil blockage?
ok.. lemme do a quick recap of the day.
put air in the tires, siphoned fuel tank, new battery, fresh fuel, checked fluids. changed the oil and filter not once, but twice.
before I attempted to start the vehicle, I checked the oil (even though I had just changed it). the level was wayyy up the dipstik. I had put in maybe 6 quarts at the most. 5 + one in the filter (one to many yes) but not so much to have oil inches above the max fill line on the stick. So i loosened the plug to let some oil out, and it was again pitch black. At this point the car had not fired, just rotated via starter. So i got another filter and another 5qts of oil. I drained the oil again, and refilled. Again the stick shows that there are 5 qts or so too many in the motor.
So.. I dont want to run the motor based on the stick because i know i drained several quarts of oil out of it. but im afraid there may be some blockage or something that could blow the rings or kill the motor. Ill make a new thread on this question. pics or vids comeing soon,max
So.. I dont want to run the motor based on the stick because i know i drained several quarts of oil out of it. but im afraid there may be some blockage or something that could blow the rings or kill the motor. Ill make a new thread on this question. pics or vids comeing soon,89 townie, mild exhuast up grades, soon to have loud ass stereo....
I'm confused. How exactly would a dipstick indicate that you have 10 quarts of oil in the engine instead of five? Obviously, it'd read quite high, but it's hardly calibrated except for the crosshatched area right around the normal fill point.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostI'm confused. How exactly would a dipstick indicate that you have 10 quarts of oil in the engine instead of five? Obviously, it'd read quite high, but it's hardly calibrated except for the crosshatched area right around the normal fill point.
tldr - if x is 5 then 2x is 10max
