High I was referred here by 87_Crown_Vic from another forum, long story short i am going through quite a bit of trouble finding some fender trim for my 91 grand marquis, everything aftermarket is wrong and the garage cant get them anymore. 87_Crown_Vic says there are a few members here from the east coast, Im in NH, and that someone may know of a hot spot to get them. Any help would be much appreciated, this is the last piece i need for the cars restoration to be complete!
Fender Trim?
- Oct 2009
- 2878
- Keene NH
- Send PM
Fender Trim?
1985 GMC 1500
Tags: None
maybe try the looking to buy forum? Your Request would get a lot more relevance. Good luck finding that part, Im assuming you've tried salvage yards. Oh, and one more thing:
Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Hi, I recently installed some nice fender trim from Fenderworld.com on my 85 Ford LTD Crown Victoria. My installer, who was already doing final paint touch-ups, said they were almost a perfect fit, but he had to do minor manipulations for a better fit. As well, he added a rubber seal.
Here are some pics. I think they look great, but they're certainly wider than the originals.
It's very hard to tell, but both whole fenders are not original. I found them at everdrive.com. The one give-away would be the lower left and right light openings. I have only seen those opening on the 4-door version, as opposed to my tudor (see, I'm already getting onto the lingo here
1985 Ford LTD Crown Victoria
...at the 2009 Huntsville Car Show, Huntsville Ontario
I have some wheelwell trim I took of my '81 (I think it looks better without it), but some of it is dented and would require restoration. You may well be better off getting some from one of the fabled U-Pull-It yards in PA.
Do you need any corner in particular?Last edited by 1987cp; 10-07-2009, 04:58 PM.2012 Mazda5 Touring | Finally working on the LTD again!
I just got a pair of NOS fronts from Green Sales in Ohio. They were $35 each. They only had left rear and it was over $100. Still looking for a right rear myself (new or good used). The reproduction stuff on Ebay won't fit a 88-91 Grand Marquis because it is made for cars with the wider rocker molding (pre 88 Grand Marquis and all Crown Vics) but it is of good quality and only cost about $12 per side (only the fronts are available though).
Here is a 1991:
It has a bright aluminum rocker molding.
Here is a 1987:
It has a black rocker molding and bright aluminum trim above it on the bottom of the doors. The wheel lip moldings are about 3" shorter to accomadate all the extra trim. Low level trim Crown Vics like police package (like mine) also need the longer wheel lip moldings.
If you order from Green, you will need the part numbers:
E9AZ16038A right front
E9AZ16039A left front
E9AZ5429165A left rear
E9AZ5429164A right rear (but not in stock)Last edited by neums; 10-08-2009, 01:41 PM.
No, not glued, about 6 or 7 small screws. I found the best way to remove them is to insert a phillips head screwdriver into the screw, then whack the handle of the screwdriver a couple of times with a hammer. This loosens the screws up enough so you don't strip the head trying to turn them. If you do see an undented passenger side rear molding on a 88-91 Grand Marquis, I would be very greatfull if you snagged it for me. It seems like all the cars I find in the yards around here have been hit right on that wheel.
