Timing
    Timing
    I just put a new Accel modular on the Distributor to help the out put of my super coil. the timing on the car seems like its off due to a hesitation between 30 and 40mph and exhaust bafeling. does anypne know the stock timing degrees it should be set at or how high of a degree i am able to go. the motor is a stoc 5.0 in a 90 vic
    10 degrees BTDC.
    is the procedure.
    Not sure about those Accel modules. I put one on my car and it died on me 3 months later. I put the original back on and its been fine.
      thanks
      yeah.. thatnks i think he accell modual was defective so i decided to put the sock one back on and it runs great.
        10 Degrees...Bump It Up To 12 Or 14
        sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
          Or leave it at 10, which is stock. Not gonna see a huge gain going 12-14 over.
