Such a NoOb Q I HAD to post it here.
    What should I expect to pay for a Dyno pull ?
    What exactly does a car go through on a dyno ?
    I have watched a ton of youtube pulls. So I notice there is a low rpm event and a HIGH rpm event..What happens right then ?
    $50 bucks for a WOT run that may destroy your motor.
      Could I possibly get a little more detail.
        There's a place called Baker Engineering over in Nunica that will let you do a couple of test runs for $50.
        Baker Engineering has been at the forefront of innovation, seamlessly merging visionary designs with precision specifications.
          ok..Maybe I should rephrase my question.
          I pay for dyno run. they pull car in and pull up on the dyno...what happens after that....
            the dyno puts a load on the car and it's run from the lowest RPM possible in 3rd gear to the maximum rpm. The dyno figures out the hp and tq from how quickly the car can accelerate the dyno rollers.
              Really ...in 3rd huh. Wow.
                Hello noob...
                Be good, if not, be good at it!!
                Originally posted by N A
                RideIt, I hope you know we are going to screw with you because you're the coolest chick on this 'site.
                Originally posted by p71towny
                Your one of the most kick ass girls I know.
                :golf: :golf: :golf: :golf: :golf:
                  3rd is 1:1 drive ratio, so no torque multiplication in the transmission.
                    Thank you all.
                      yay... i found a dyno in my area... prices are reasonable from looks depending what i want tested.
                      Get set up with a new domain name right away. Affordable payment plans to fit any budget. Friendly customer support.
                      DynoSport is a great name with multiple uses in many business verticals. Whether it's sports, cars or tech, DynoSport.com will give your brand authority in the marketplace. Own DynoSport.com today!
                      Addicted to 86-87 Panthers
                        Sorry about being off topic, but Jim that avatar is amazing.
                          i kinda snagged it from a person on a different forum. thought it was different...
                          sorry for the off topic
                            if you get in with a group you can get lower rates. i paid $30 for two pulls.
                            you pull the car onto the rollers and either they operate the car or you do it. but you pull from the bottom of third (you can also do it from other gears, some turbo cars do this to load the motor better) to your redline. it is no harder on your motor than punching it on the interstate.
                              how do you take one of our cars for the third gear so at it?
