That thing is a beauty!!!! Doesn't look like the light conversion was too hard either, with the ditch lights and the backup lights where they are and all...
Gotta love midnight blue
1983 Grand Marquis 2Dr Sedan "Mercules" Tremec TKO conversion, hydraulic clutch, HURST equipped!
nice!
what's with the light under the back bumper?
1984 Grand Marquis GS - CFI-SEFI conversion, Explorer 302, GT40 intakes, GT40P heads, 1.7 roller rockers, HO Cam, ASP Underdrive Pulley, 2.5" Dual exhaust, Flowmaster Delta 50 mufflers, 3.55 Trac-Lock, Rear disk's, Moog cargo coils, ES rear poly bushings, PI front and rear sway bars, 3G alt., Mark VIII fan, custom Auto-meter dash 1990 Crown Victoria Country Squire - Explorer 302, HO cam, dual exhaust, 3.55 Trac-Lock, PI rear sway bar (SOLD)
nice!
Scott, all vehicles in the UK are required to have a rear facing spotlight, red in colour of course...
Part of the "light conversion". Also, the ditch lights will be turn signals, and the reverse lights will have amber bulbs for use as turn signal,s and revers lights aren't even required!
European cars have to have slightly different exterior lamps and lighting behaviour... so US cars often wind up with extra lamps added/changed/re-wired
Huh, I think ( same rules in Holland... European Union ) it's a fog-light.
And my GM still has all the original lights, and NO conversion of amber bulbs
in the reverselights..
And reverse-lights are required !! ( failure as far as I know of MOT or the Dutch version called APK, no valid licence...) )
1996 Grand Marquis LS ( fully loaded)
2006 Mercedes S320CDI (lwb)
1996 VW Golf Convertible (fully loaded)
