1984 Marquis Gentleman I'm trying to do an engine swap from a 1988 Towncar 5.0 efi
    Here's the idle set procedure. Ignore #1. No feeler gauge needed. And use 10 degrees for #2. The rest is the same. Use A values (automatic) on the rest. Skip #7, 8, and 9. 13 can be looked at if shifts feel soft.
    Is this for CFI or SEFI????
    1987 CV LX 5.0
      I think at some point it bundled into the ECM harness but not sure when. I just remember doing a swap on something and ending up with two wires for the solenoid, one from the original harness, and one that came along with the new harness. I don't exactly remember what car that was though.
        Ok thx will work on it this weekend thank you for the help
          That's for SEFI (for the 88 engine)
            Good Evening Gentleman my question is if you guys can help me with this wires.Im pretty sure is the neutral switch wire that has to tap into ignition module
            Is W for white and R for red wires?please and thank you
              This is the correct picture
                Yes, W is for white and R for red. The color code after the / is for the stripe.
                  Would you happen to have a diagram of the gauge connecting wires from this plug.The wire go into the dash gauges and to engine but when swapping out did not label
                    best I can do. Not really much for gauges, just some "you're screwed" lights for water and oil pressure. If either come on, its basically too late.
                    Low oil level is also on that sheet, but different connector.
                      Thank you very much
