Well, home for thanksgiving, so I'm installing my component speaker system. Checked it all out and found a problem when I opened the box. One of my crossovers was broken. The largest coil had broke one of its wires to the bourd from not being secured to the board. So I decided to redo all of them on both crossovers, so that it would no longer be a concern. Started working on it and found the old speakers that my Dad put in the door many years ago. They had become glued to the door hehe. It was then that I found out the bad news. The whole in the door is for a 6" speakers not a 6.5". But I'm still putting them in there anyways, because just happens that my speakers have a 2nd ridge in the frame that sits on flat
Lucky again because if this did not happen, and the speaker went all the way in, then it would have interfeared with the window when rolled down. But again not an issue for mua. Lots are probobly asking, "why don't you use the fatory speaker grills?" I hate them, I think they are out of place, way more so than what I am doing.
Anyways. Speakers are again Cadence. They are 6.5" component systme speakers with 1" tweeter. 6.5" is aluminum cone, tweeter is silk soft dome. 20oz magnet structure. 100watt rms (200watt max) each. And let the pics follow!
