Well where do I start?....I'm new to this type of computer use,not very sure I can get any facts about swapping a v10 into the 89 colony park...from what I've gathered its been done with a few areos,but cant find anything on the "box" models...Hope someone can help as I've picked up a ZERO miles v10 and 4r100,all harness/pcm for an rv,no rev limiter type,Y pipe,rad.ect...Wingfoot
V-10 in a Wagon
we need pics! lol ...and welcome!
Pirate has talked on and off about putting a Ford V10 in a Panther or Thunderbird. Other than that, I've personally only heard about it in magazines, and then only in Mustangs (not that that's that different).
Personally, my logic as of late is that if a guy I know of from another forum can get 2hp/ci out of a 347ci Windsor, NA, I have no need for a fancier type of motor. :p2012 Mazda5 Touring | Finally working on the LTD again!
just fyi: hood will not clear the v10 intake... other than that... cut the hole in the hood and haul ass!
There's already that v10 whale out there. But that's been done for years.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
YEE HAA,it worked!...Will try to post more pics as the swap progress is slow at this time.Still looking for any info on mod motor swaps...I'm a proto type metal model maker so I have no fear of SPARKS and BURNS!....I'm also thinking about a two door panel wagon,a modern version of the old ranch wagon.combing roof panel and rear door from a wagon onto a two door box...but for now I want to focus on fitting the v10/4r100 into WingFootwagon.....
cowl hood and you're good to go.sigpic
homina homina homina
That is sweet! If you weren't having hood clearance issues, I'd say slap a S/C on there, to get the Sound that Pirate really likes (lambo sound). There's a video on youtube with an S/C V10 and it sounds beautifulParts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For Sale
Originally posted by wingfootwagon View PostWell where do I start?....I'm new to this type of computer use,not very sure I can get any facts about swapping a v10 into the 89 colony park...from what I've gathered its been done with a few areos,but cant find anything on the "box" models...Hope someone can help as I've picked up a ZERO miles v10 and 4r100,all harness/pcm for an rv,no rev limiter type,Y pipe,rad.ect...Wingfoot1983 Grand Marquis 2Dr Sedan "Mercules"
nice wagon! and the tips on the exhaust look good. this should be an interesting build!
Your main issue, as you may have figured, will probably be length. Routing exhaust could also be a challenge. A small block ford is 29 inches long, and a 4.6 is 36 inches. I can't find the exact number, but you're probably talking an engine 10 or more inches longer than stock if you go V10.
Baumann's 4r100E controller (or equivelant, if there is one) will be needed http://www.optishift.com/
Originally posted by johnunit View PostYour main issue, as you may have figured, will probably be length. Routing exhaust could also be a challenge. A small block ford is 29 inches long, and a 4.6 is 36 inches. I can't find the exact number, but you're probably talking an engine 10 or more inches longer than stock if you go V10.
Baumann's 4r100E controller (or equivelant, if there is one) will be needed http://www.optishift.com/1983 Grand Marquis 2Dr Sedan "Mercules"
