from a newer panther, of course.
This upgrade has many practical uses, including making room for cold air intakes, a battery, or for aesthetic reasons
This washer tank is from a mid 90's vic or gmq. To fit it in I had to move the voltage regulator, but otherwise it fits great. It even lined up with one of the holes for the regulator.
*FIRE HAZARD* --- If you have an externally regulated alternator, the voltage regulator MUST have a ground to its case while the charging system is operating, or the harness will catch fire. Our fender wells are plastic, so a ground strap is needed. Mine is now grounded by a 10 gauge wire to the radiator support, so far so good.
You guys with 86-89 MPFI will have to move your relays. Have fun! :P
I like this better than the original combo reservoir... I plan to upgrade to the '90 TC fan shroud w/coolant bottle too, as soon as I find one.
