Okay, a few weeks ago I walked out to my car (at work) after it had been sitting for about 20 minutes and noticed an anti-freeze puddle under it. Puddle was under the front/middle of the engine. I had a leaking front (oil) drain plug at the time so it was hard to tell were the source was, since that part was wet with oil all the time anyway (and my color vision is iffy).
Well, since I didn't pay attention when I parked.....for all I know it was already there beforehand. The level did go down a bit, but I had also just put in a new radiator and thought there might still be some air in the system.
Well, I've been hearing a gurgling in my dash and have been a bit paraniod about it. So I have been keepng a close watch on my coolant level. (no anti-freeze smell inside the car at all).
Well, today I cought it in the act. It's coming from the bottom of the water pump.
No hoses are leaking and the front intake manifold area is dry.
No overheating issue's either.
It appears to be coming out of a hole cast into the bottom of the water pump.
The gasket could be leaking under there too, but it is hard to tell.
The expansion tank was very overfull the 1st time this happened and was still slightly overfull today. I'm sure it will drop a bit when I leave work tonight. (just like it did before).
Is there some kind of "blow-off valve" in the waterpump? (for when the system is too full?)
It only does this after I have parked and shut off the car.
I'm assuming I need a new water pump? (my car has 81k miles on it)
Thanks for your help.
