Finally got around to dropping a 3G in... I sure do love the easy mods!
I used a small case 3G, and it fit my 65 amp external regulated alt brackets with no cutting or grinding. Getting the belt on was a little tricky, since the 3G pulley seems a tad wider, and the bulkier case of the 3G limited the tension travel to the last half of the adjustment notch.
I just used the longer 505 belt and loosened the alternator brackets up, this gave me just enough wiggle room to pop the belt over the pulley.
I used an OEM 3G charge wire I found in an early 90's Explorer - this one has two fuse links in the wire and was just the right length to reach my fuse box. It looks like if you dont tuck it away, it may reach the + terminal of a top post battery...
I wired it to 'sense' off the output stud temporarily until I work some mojo on the fender end of the old wire harness to splice this and the excite/warning lamp wires in. A few of the wires behind the car-end of the connector are cracked up... I want to pull each one out of the connector and put some shrink tubing on them...
I also learned that the warning lamp circuit IS the excite signal for the thing to charge... I knew the green wire was for the lamp circuit, but I didn't know it was needed to charge. When i started it up it didn't charge until I made a quick-jump for the warning lamp circuit...
wiring I removed (this is also the old coil wiring... its unused since the SEFI conversion eliminated it and it shares the alternator harness)
I also installed the vacuum box/relay holder Tom brought me... the one and a half studs worked great mang!!
