Aftermarket upper control arms
    flipping through Speedway Motors catalog yesterday i decided to go measure the upper control arms on the 85.
    the 85 uses a 7 3/4" bolt spacing, 8.25" legnth and an offset design (offset by 1 1/4".
    A 1970-1981 Camaro uses upper control arms that have a 73/4" bolt spacing and come in lengths between 8 and 9 1/2" in 1/4" increments. But it is a non-offset design.
    they both use a four bolt upper ball joint
    the Camaro arms are almost a perfect match.
    Today i was looking through a catalog from www.a1racing.com/
    They have control arms in the proper spacing, length, and offset, with 4-bolt ball joints in either aluminum or steel. They are about $50 each.
    Their site does not list the size, but ill look it up in the catalog tomorrow, even in steel these arms would easilly cut about 10#s off each side of the front suspension, im going to look into the aluminum arms for maximum weight savings.
    This is what they look like. compare that to the heavy stamped control arms on the box panthers.
    The only thing im concerned with is how the panther control arms are bent up at the ends, im not sure if the chevy arms are or not.
    Interesting... Nice unsprung wieght savings.
      yup, im interested in the aluminum not only for the weight savings, but for the reduction of unsprung weight to get the front end up faster and keep it up longer.
        hehe... keep it up longer... I'd like to attempt to make tubular 98-02 uppers.
          interesting
          LTD is still here
            Um somebody work this out and tell us all ...PLEASE
              these are the steel arms in 8" legnth
              http://a1racing.com/index.asp?PageAc...arch=GO&Page=1
              aluminum in 8"
              here are 8 3/4" in steel
              8 3/4" in aluminum
              They also have a 91/2"arm but i think that is too long unless you need radical camber changes.
                The rear lowers are very close to GM A and G body arms also....
                  I've seen those lower arms and noticed the same thing. I think in the late 70s ford engineers just stripped a few GM cars and used their suspensions. The panther suspensions have more in common with GM suspensions than with any other FoMoCo vehicles
                    can these possibly work on my wagon b/c lord knows i can loose some wieght on this car
                    1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
                      if they work on a sedan then they should work on a wagon
                        I guess its time to bother some camaro people and get a better look at these. It doesn't look too terribly expensive.
                        -Matt
                        1968 Fairlane 500 - 1998 Camaro Z/28
                          I dotn think the Camaro arms will work since they are not offset. im nto sure exactly which GM chassis uses the correct arms. Maybe Monte Carlo?
                            There are so many other places to loose wieght
                              well i m accualy ditching i think probly 60 pounds in wieght with stero equipment and i dont know where to start cutting the fat next thou
