Windows not rolling up, but you can hear the gear turn?
This is a sticky topic.
I tore my passenger rear door apart, to replace what i thought was just a bushing problem, but it turns out my plastic gear that they fit into was cracked across it
The one on ebay is just the plastic gear and bushings. A little cheaper but you'll have to wait.
'80 Town Coupé
Rebuilding the stock motors seems to work out better than some of those cheapie motors. We got a set for the SuperLinc, one was bad right out of the box and even after fixing the poor assembly problem it wouldn't run the window up reliably. I ended up pulling the transmission out of it and slapping it on the stock motor, now it works fine. The other front door has a new China motor, and in 3 weeks its gone from working OK to being slow and making a rather loud horrible noise when you operate the window. I'm gonna yank it apart and use the transmission in the old motor.86 Lincoln Town Car (Galactica).
Originally posted by Grand_Marquis_GTsaves having to wait on that great ebay shipper!
Now more than ever am planning on complete rebuilds for my window motors, I want those windows to jump!
1991 Crown Victoria LTD, Puff the Magik Dragon
I put new bushings and good used brushes in my passenger motor - it was good for two years untill it got stuck down again last week.
I ordered a rebiult one from fisher... and they are getting a core back with no bushings in it
I think keeping them sealed up and water tight is important... the insides of my motor were all nasty looking.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I have the exact same problem. I had the motor out and it moved just fine, but under the weight of the window, it's another story. I can hear the gears turning. And you can move the window up and down by hand.
So you can rebuild the motors? That's nice! Is it hard? How much does one of these kits cost? What internal parts do these kits have? Fill me in, I am also replacing a window motor.
Originally posted by 86VickyLXI have the exact same problem. I had the motor out and it moved just fine, but under the weight of the window, it's another story. I can hear the gears turning. And you can move the window up and down by hand.
LOL, man did you read the posts? there is a link with the price right there!
There is one screw and the parts drop in. It's easier than removing the motor.Builder/Owner of Badass Panther Wagons
I think I might as well, while I'm in there. See I think what this thread said is the exact thing I have problems with. The motor works without the weight of the window, but when it's in there, it just makes noise, and the gears turn. Is it gears? Or something else?
If you can hear the motor, it's the gears or torque pins in the gear drive. They are like big erasers that prevent you from decapitating people with the windows. They wear out and then the window won't go up.Builder/Owner of Badass Panther Wagons
what you talkin about darkenssPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by mrltdIf you can hear the motor, it's the gears or torque pins in the gear drive. They are like big erasers that prevent you from decapitating people with the windows. They wear out and then the window won't go up.
Dear Panthers,
I'm two time zones from home, in western north dakota dog trialing and the other day my driver's window wouldn't roll up. 4:30 on the Saturday of memorial day weekend, in a tiny dakota town. Well the window had to go up even if I had too leave it up. I have a tool kit but no ratchet so I raced to the hardware store for ratchet - and in case that failed, clear plastic and duct tape.
I've had motors fail before and usually they go slow and noisily. This went without noise. When I threw the switch I heard a faint click, no better. Well I got most of the panel off, enough to get a hand in there but the window wouldnt't budge. Enough is enough. I took everything worth stealing into my motel room and figured Sunday I'd ask the trial host if he had a ranch shop so I could disassemble the whole door.
On the way to the ranch I hit the button and it worked fine. Tried it a couple times, rolled up and down, silently, like a good window. Well, I'm a long way from home so I ordered a new motor from Pete Veitch and I'll leave the damn window up until I get home.
But I'd appreciate your suggestions what the trouble might be.
I hit a deer fifteen minutes after leaving home -3 am -three weeks ago and wrecked the front of the car. Radiators were okay and I had three headlights which are plenty going through West Virginia, so I kept on trucking. In Wisconsin I had a mechanic jury rig something so I had four headlights, more or less aimed. He told me I had a short somewhere in the front - kept arcing.
Might that have something to do with it?
Donald McCaig
