My car (a 2000 Grand Marquis LS) developed various suspension and steering issues by about 170,000 km. I’ve talked about my rebuild experiences in the following two threads:
It turned out that the stabilizer bar bushings needed to be replaced after everything else, and I did that yesterday.
Getting the correct bushings was a bit of a pain since there are various sizes. My bar is straight between the bushings and measures 28.5mm in that area. The correct bushings were apparently 8732's, which were listed as being for a 28.5mm to 29.5mm bar. This would have been fine enough, but Moog recently changed part numbers. Now they have 200167's, which are typically listed as being for a 28mm bar, and 200168's, which are typically listed as being for a 29 to 29.5mm bar. I ended up getting a cheap brand of 8732 bushings. The bushings themselves actually indicate they are 29mm.
When I got the bar and bushings off, I was horrified to see a very thick version of the flaky rust problem. After getting it all off and wire brushing the bar, I had some curious measurements. Right beside the expanded ring part of the bar where the bushing sits, I measured 29.5mm. Moving across the bushing area, the diameter went down to 28.5mm, and then plummeted to 27mm at its lowest point. I have attached photos of these parts of the bar showing how badly the bar had been corroded.
Is the part of the bar where the bushings sit supposed to be a uniform diameter?, or does it actually have some kind of fancy taper?
Incidentally, one issue I couldn’t figure out beforehand was which direction the slit goes. I figured the old ones would tell me, and I was right. I have attached a photo of the bushings showing noticeable wear on the rear outer parts, suggesting the slit should be at the front. [The two marks at the 4 o’clock and 5 o’clock positions on the bushing on the left (from the passenger side) and at the 8:30 and 9:30 positions on the bushing on the right (from the driver’s side) were made by me with a hacksaw blade while the bushings were still on the bar so I would know the orientation after they were off. All the other problems are a reflection of how bad the bushings were.]
