i was curious if anyone knew what the width of the steel 15" rims was? also what would be the widest tire i could fit on there safely? i was going to go with 225 70 15s or 235-60-15s if those would work better on the front but want something wider on the back, but ive seen other people on here have no problems running 235-60 15s all around? would yall recommend that?. does anyone reproduce 15" steel rims with say an 8" width? since i want to keep a stock like appearance to the car and not worry about blowing the rear tires off it everytime i hit the gas.
i want to be able to use hubcaps like these pictured below (btw below pic is not my car but ill probably end up painting it like that), or the other style of similar hubcaps that say ford motor company around them, so that probably rules out the rims like armo has on his car, since they are steelies but i dont think these center caps would fit those since they are made to have the hubcap sit inside the ridge and not go around the outer center ridge if ya know what i mean
