Interior Lights will not cut off
    Another problem here that I can't find anywhere in the manual.
    My Interior lights will not cut off at all, for as long as the battery is connected.
    When I first got the car, the Interior lights would cut off normally when the doors were closed, or the door jamb switch was pressed.
    At the time the car had a bare ignition switch, which I was using a screwdriver to switch back and forth between the positions. One of the times when I was attempting to start the engine, the Ignition Switch shot out a fat blue spark which shocked me, and afterwards the Interior Lights would not go off at all, or since.
    Anyone have any ideas as to what could have happened?
    Hmmm... the interior autolamp feature is tied into the ignition switch I think , iirc after you enter the car the interior lights stay on for 30 seconds or so OR untill you turn the key...
    Does this box have this feature??? there is bound to be some sort of module for this... maybe its just fried and is something you can find and unplug for now.
      Yes, this Box does have Autolamp, as well as Illuminated Entry and Delayed Exit. I didn't see any sort of module for it while I was under the dash though.
        did you replace the ignition switch?
          I'm with Scott.
            Yep, replaced the ignition switch awhile back with the one from the parts car, which had a key. Still no change afterwards.
              stupid question but your headlamp switch isn't rotated all the way clockwise is it?
                Lol, I did think of that, and no it isn't, I made sure.
                I'm beginning to think that it may be the Autolamp switch itself, I'm gonna try unplugging it and see if that changes anything. I can't think of anything else that would hold the lights on like this.
                I think this car hates me...
                  Woohoo! Figured it out and Fixed it today. The Autolamp switch was indeed the problem, got lucky and found an NOS unit from Team Ford at the local stealership.
                  Replaced the switch earlier today, and all the Autolamp features work now, and most importantly the interior lights cut off 30 seconds after I close the door, or right after I turn the key.
                    the key lock is not the ignition switch man
                      Glad to hear you sorted that out, have you noticed any difference in cranking the engine now? The switch might've been doing more than just keeping the interior lights on.
                        Yea, I know that scottmang. What I meant was that the replacement Ignition Switch now has a Key/Lock Cylinder/Actuating Rod, now operating it. Instead of a Screwdriver like before. I was at work at the time I typed that, and just got in a hurry and worded it wrong. It's all in my RR thread, with pics.
                        Thanks. Sadly no difference with cranking the engine after changing the switch, but the Interior lights always staying on were REALLY aggravating me, so I'm glad I figured that out at least.
