couple question ok i have been thinking about carbing my car what will i need?? question2 what kind of headers can i use on a all stock gm stock motor {i heard any short header should be fine}?? question3 what kind of gears can i but in the rear daily driver?? question 4 iam going to be doing a tune up soon and was woundering should i get msd wires cap rotor and ign?? thanks guy any help would be great
headers and rear gears
1.) A carburetor, a carbureted intake manifold, a new ignition system, a modified fuel pickup in the gas tank and an aftermarket electric fuel pump or a mechanical fuel pump and new timing cover with the provision for the mechanical fuel pump, some custom fab'd fuel lines in the engine bay at minimum... lots of electrical removal (buy an EVTM to see what wires and sensors you can eliminate).
2.) Fox Mustang Shorties, unequal length. The stock HO tubular manifolds (basically a header) fit nicely with a stock engine. Don't go larger than 1 5/8 on the primaries, I'd recommend 1 1/2 inch on a stock engine.
3.) 3.55's are good for a daily driver. 3.73's are okay too, especially if you stay under 65 mph for the most part.
4.) I'd wait on the ignition until you do the carb conversion. Stock replacement cap and rotor should be okay until then. If you'd like, try to get brass terminals in the distributor cap (they don't corrode as bad as aluminium ones).1990 Country Squire - under restoration
why carb an efi car? your mileage will go to shit!
3.55 or 3.73 gears and a trac lock are good fun
use shory headers for a mustang and the h pipe
Originally posted by lincolnmania View Postwhy carb an efi car? your mileage will go to shit!Originally posted by gadget73There is nothing more permanent than a temporary fix.
I average 17 with a carb on the highway. With a b cam in it no less. Depends on the engine set up.1989 Grand Marquis LS
if it's a DD, I strongly suggest leaving it it EFI.
doing a full HO conversion will get you into the low 16s in the 1/4 mile if you have 3.55s.
or if you can find a good set of GT40 heads, those are good.
an HO intake is better than the stock one, but an Explorer or GT40 is better from what I hear.
Summit Racing sells some nice Ceramic coated shorty headers for 302s that are a great value..I got em on my car. 240bux and they are VERY thick and heavy duty compared to the other shorties out there.
for gears...I got 3.55s..I like em but my hwy mpg with my EFI motor going about 70-75mph was 21.5.
city with them was as high as 18. I swear I noticed a difference with a K&N filter on the stock air cleaner setup..went from getting 17 in the city to over 18.Last edited by Mr. Land Yacht; 06-23-2008, 10:46 PM.sigpic
You may also have problems getting it through emissions with a carb. Not sure the laws there in Chicago though.86 Lincoln Town Car (Galactica).
wow guys u real came thou this time lots of good info!! the whole carb thing was just a idea i had wasnt to sure of real doing it but it sounds like alot more work then i thought!! iam trying to keep my engine org till i swap out where i can pick and chose what i want i am serious about the headers and gears thou really all iam trying to get is my car to sound a little more louder right know i got stright pipes with some cherry bombs!! has far has emissions my car dosent ever have to go again so that a plus i was thinking about getting ride of 2 of the 4 catssigpic1987 grand marquis
the B cam isn't well suited for a heavy car, and I doubt the stock EFI will run well with it. Mustang mass air stuff will do it but with those lousy heads, you're going to end up with a huge turd of a performer.86 Lincoln Town Car (Galactica).
