Automatic Headlight Wiring
    Well, I am considering putting automatic headlights in Vicky. I already have the switch and the sensor for it. Now I went to the junkyard yesterday because I wasn't sure where some of the wires went. So I followed the wires and some went to a relay near the radio (behind the radio and to the left). So I am confused cause I don't have that relay. Did Ford add a relay to newer vics/gms? The wires I followed were from an '89 GM. The connections are different from the ones that I looked at in an '85 vic. I can't remember if there was a relay by the radio or not. I'm sure they changed the connections in 3-4 years. So I will go to the yard maybe tomorrow and pull apart an '86 with automatic headlights and see what goes where.
    Does anyone have an EVTM? Could someone scan the pages for the headlights both manual and automatic headlights so I can see what wires I have and which ones I don't?
    Hi 86VickyLX
    You have taken on quite a project. There are actually three relays in the system, a flash to pass relay, a delayed exit relay and the hi-lo relay, fitting autolamps is reasonably straight forward fitting autodim is a little more technical.
    Hope you got the rear view mirror to mount the autodim sensor on as the sensor is mounted at a 5 degree angle to the right.
    Here is the autodim wiring.
    And here is the autolamps wiring.
    Regards
    Dereck
    President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
    Also "The Pondside Pain In Your Posterior"
      Thanks Dereck! Do you know if the settup was changed at all between years?
        Hi 86VickyLX
        The diagrams I supplied are for an 88 Town Car, I would have expected very little change from 86 - 89 and indeed 90 - 94 is very simular.
        As you are retro fitting the system you could pull just about any of the components from just about any year car and wire them in yourself, I would grab the component and a short length of the harness.
        For the relays you can use any change over rated at 25 amps or greater and a double pole change over relay for the delayed exit one, you do not need the Ford ones with the funny pin layouts.
        I retro fitted autolamps to my Excursion but decided for the extra work involved I didn't really need the autodim feature.
        Regards
        Dereck
          Originally posted by Dereck View Post
          Hi 86VickyLX
          For the relays you can use any change over rated at 16 amps or greater and a double pole change over relay for the delayed exit one, you do not need the Ford ones with the funny pin layouts.
          Regards
          Dereck
          What is auto dim?
            What is auto dim?
            Hi 86VickyLX
            Autodim does exactly what it says on the box it automatically switches the lights from hi beam to lo beam when a sensor mounted on the mirror detects the lights of an on coming vehicle.
            I thought your were trying to fit a whole autolamp/dim system, if you are only fitting autolamps then the job is simpllicity itself you do not even need the autolamp main light switch all you need is the day/night sensor, an on/off switch, a two pole change over relay (the delayed exit relay), a 54 - 60,000 ohm resistor (this will give you about 30 seconds of delayed exit headlights) and a bunch of wire.
            Let me see if I can whistle you up a simple wiring diagram.
            Regards
            Dereck
              Hi 86VickyLX
              Regards
              Dereck
              Yeah I just want the autolamps.
              The main auto lamp switch, do you mean the headlight switch?
              I havew the day/night sensor, in fact I have two of them. Where can I get this resistor? And what do you mean by an on/off switch and a 'two pole change over relay'??
                Hi 86VickLX
                Okay pick the bones out of this!
                You do not need a special headlight switch to work the autolamps you can use your existing switch, you will simply need an aditional push button switch to turn your autolamps on and off.
                The resistors you can buy for a few cents from an electrical store.
                The two pole relay is a relay that has two sets of switch contacts, you need a two pole relay one for the parking lights and one for the headlights.
                Regards
                Dereck
                  So I can just tap into existing wires for some of this stuff?
                  So just to verify, the 'Push Button Switch' is the headlight switch right?
                  What is the main light switch?
                  and what's the box at the bottom.
                    Originally posted by 86VickyLX
                    Hi Dereck,
                    I Love You!
                    Regards,
                    86VickyLX
                    Hi 86VickyLX
                    Err I hope you are female
                    Yes you just tap into your existing wiring, technically speaking you fit the autolamp system in parrallel with your original headlight wiring
                    We seem to be getting our terms confused.
                    Main light switch = The headlight switch.
                    Push button switch = A switch you will fit to turn the autolamp feature on/off.
                    The box at the bottom? If you mean the one in the blue wire it is a resistir for the LED that tells you the autolamps are on. The LED can be built into the switch or you can fit one separately.
                    All LEDs need a resistor to work allthough some come with a built in resistor, the electronics shop where you buy your illuminated switch or LED should be able to tell you what value resistor you will need from memory it will probably be about 2000 - 2200 ohms
                    Regards
                    Dereck
                      Hi 86VickyLX
                      Regards
                      Dereck
                      No I am not a woman. I was just very glad that you had dumbed the thing down for me.
                      As for the box I meant the one to the right of the resistor for the LED.
                      And for the push button switch, what kind should I use? And just a question, why would I want to turn it off?
                        Hi 86VickyLX
                        I beleive you are refering to the two pole change over relay, like this one
                        The push button switch I used.
                        You probably will not want to turn it off but you never know!
                        Regards
                        Dereck
                          ok thanks so much!
                          is it possible to use a toggle switch?
                          Where can I get the relay from?
                            Hi 86VickyLX
                            What's this the Vicky and Dereck thread
                            Yes you can use a toggle switch, it doesnt even have to be illuminated, I put the switch illumination in for aesthetic value, I even wired the illumination into the parking lights so that when the autolamps are off but the lights on the switch illuminates dimly and when you turn the autolamps on it illuminates brightly.
                            I don't know where you can get a relay from I am in the U.K Just do a web search for a mail order company, I believe Farnell have an American site or try a local electronics shop.
                            Regards
                            Dereck
                              Hi 86VickyLX
                              Yes you can use a toggle switch.
                              Regards
                              Dereck
                              ok thank you and yes this is the Vicky and Dereck thread :p
