Box front end conversions-the basic lowdown DUW
    The nice thing about boxes is the general interchangeability for major body panels, with the exception of the Town Cars. It would take major modifications to make Town Car parts fit on a Crown Vic or Grand Marquis. I'm also only covering front end conversions. I will be referring to both models as simply Crown Victoria and Grand Marquis. I am well aware that the earlier models were LTD and the Crown Victoria was a trim level. The same theory applies to the Marquis. It will be easier for everyone that reads this if I stick to Crown Victoria and Grand Marquis.
    Lets start with the fenders. The fenders are identical on the Crown Vic and Grand Marquis. The only differences being that from 1979-1981, possibly 1982, were that the Mercurys had louvers in the fenders. The Crown Vics never had the louvers. Older cars optioned with power antennas had the antenna located in the rear. I'm not sure what year the power antenna was moved to the front fender. I know my 1988 Grand Marquis has the power antenna in the front. The only other difference is that some cars were optioned with ditch lights, some weren't.
    Now to explain the differences between the hoods. The Grand Marquis hoods stayed the same from 1979-1991. The Crown Vic had two different hoods. From 1979 to 1987, the hood was unique to the Crown Vic. From 1988-1991, the hood was the same one used on the Grand Marquis.
    The header panels are the major noticeable difference between the Crown Victoria and the Grand Marquis. The Crown Victoria had 3 different header panels. There was the 4 headlight panel from 1979-1987. There was also a 2 headlight panel during part of this time frame. Lastly, there was the 4 headlight panel from 1988-1991. The 1979 Crown Victoria had clear lenses in front. After that, the lenses were amber. Again in 1991, the Crown Victoria received clear lenses. Moving onto the Grand Marquis, there was only 2 header panels. There was the 1979-1987 four headlight panel and there was the 4 headlight panel from 1988-1991. The grilles and hood ornaments changed throughout the years as well, though the focus of this article is not on those differences. The inclusion of the clear lenses on the Crown Victoria is due to the fact that these were one year only pieces and as such are exceedingly hard to come by nowadays.
    The bumpers are different between the Crown Victoria and the Grand Marquis, though the mounts are identical. There are a lot of variations between the older bumpers on the Crown Victoria. The 1979 bumpers are unique in that they have 2 holes in the middle with plastic that matches the look of the grille. The plate holder sits in the middle of the bumper. There are differences in the plastic trim. Some cars had clean bumpers with no trim, some had trim going all the way across the bumper and some had little plastic bumpers. Some cars had trim and no bumpers, while others had trim and bumpers. After 1979, the license plate was moved to the drivers side of the car. In 1988 the Crown Victoria's changed to match the new header panel. The license plate was once again moved to the center of the bumper, and it had plastic trim that wrapped around the bumper.
    From 1979 to 1982 the Grand Marquis had a similar slotted bumper to the 1979 Crown Victoria. Some of the cars with slotted bumpers had the license plate holder in the middle and some others had the plate holder on the drivers side of the car. I'm not sure why there is a variance with the same bumper. In 1988, like the Crown Victoria, the Grand Marquis got a new bumper. The bumper on the Grand Marquis is shaped a little differently than the Crown Victoria's bumper because the bottom of the header panels are different. The trim on the Grand Marquis bumper is thicker than the trim on the Crown Victoria's bumper. This is because the Grand Marquis has trim that runs the length of the car and the bumper trim completes the look. The Grand Marquis has little plastic bumpers like the Crown Victoria, but the Grand Marquis' are metal and plastic. The Crown Victoria's are just plastic. The little bumpers also sit right next to the plate holder on the Grand Marquis, where there is space between the little bumpers and the plate holder on the Crown Victoria's bumper.
    Last but not least, we have the filler panels. On the 1979-1987 models, the filler panel was tucked in behind the bumper to cover the gap between the fender and the bumper. On the 1988-1991 models, the filler panel actually wraps around the top and sides of the bumper. The Crown Victoria filler panel differs from the Grand Marquis in that the Grand Marquis filler panel has trim to match the trim on the side of the car. The word Mercury is also stamped into this trim.
    I would like to thank 87gtVIC and Brown Muscle for confirming there is no difference between hoods on the 2 headlight and 4 headlight models. At the time of my original post, nobody had yet confirmed whether or not the LTD S utilized a separate hood.
    Save a seal, club a liberal.
    Why does everone convert their boxes to the roundy box???? :drug: I don't get it, the sharp lines and defined features are what make this car stand out now adays. But then everyone converts it so it's closer to the look of other cars on the road....
      It's not EXACTLY bolt on, but close enough. Only thing is, you need to drill new holes in the fender to mount the filler panels. I had to going from an 87 to 90 Filler, and Tom has to(or had, not sure if he did it yet) going from his 84 to 89? filler. Let me find a couple pics you can use as reference.
        this guy did not change the hood. he went from an 88-91 to the older style header panel and he retained the 88-91 bumper and filler panel
        this guy did something similar, except he also replaced the hood.
        the problem with the above is maily the gap between the filler panel and the header panel. the 79-87 header panels had a relatively flat bottom while the 88-91's had some curve. had the people gone ahead and did the full conversion it would look alot better imo
          here is some pics of Cog's tudor
          before
          halfway completed-still needs the hood and the bumper and filler panel
          completed
            Totaly agree, the half ass job looks just like that...ass
              those pics are definitly giving me 2nd thoughts... lol
                Keepem' lookin old. The older ones are becoming more rare. unless you have a vic and you you don't want to be refered as as the person who drives the men in black car. :evil: I want to see some one make their newer box look older
                  Personally, I like the newer front end because I don't like the old bumpers. I always thought it looked like someone screwed up the measurement and made them about 6" too wide, then decided to just use them anyway. But like anything, if you're gonna do it, do it right.
                  Opinions are like assholes, etc etc.
                    We've all got one.
                      I had my asshole surgically removed. :drug:
                        I wanna see someone do a Mark VI conversion on an 88-91 Grand Marquis. Other than the fenders,u'd need to replace just about everything right?
                        Nick
                        88 Colony Park LS
                        G-pa's old car, but he's cruisin around heaven in his 69 wagon now
                        Future plans:Semi HO conversion, or Explorer motor swap, shift kit, PI springs and sway bars, KYB-GR2 shocks
                          89 nose on an 84.
                          Requires just the nose, no hood.
                          Bad pic, needs more paint, etc...
                            Re: Box front end conversions-the basic lowdown DUW
                            Originally posted by evilcrownvic
                            alot simpler on the Mercurys
                            That's cause they are mo' betta, fool!
                              That front end looks great mang. Can't wait to see the finished product
                              Nick
                              88 Colony Park LS
