kishy's 1985 Ranger
    Yeah, the side hop from a solid axle vehicle will be reduced by firming up the rear suspension, and knowing you the shocks in that truck are from 1985.
    That is one of the biggest differences in my Townie after it lost its rear sway bar, it wants to hop all over in some situations (NB I75 at Big Beaver curve comes to mind). Even on a FWD car, too soft of a shock can cause the ass-end to want to jump around. The '11-'16 Elantra is bad for that, they are a twist-beam rear and they hop all over the place in US spec. Apparently the USDM cars got softer rear shocks to give them a softer ride, swapping in firmer shocks is supposed to fix it. If my Mom wasn't leasing the '16 Elantra she had, I would have ripped out the front shocks before it had 5k miles on it. Drove me nuts. Her's had 17" wheels with lower profile tires, I can't imagine how bad a base model one musta been with 15" wheels. She had a redesigned '17 Elantra as a rental and they almost totally fixed that, it was the single biggest difference while driving it.
    -Steve
      I'll have you know they're from 2015, sir. And they aren't even bargain basement RockAuto wholesale closeouts either...they're Monroes purchased retail from Advance. However, they were garbage when new and still are today, so that's not saying much. I think they have a lifetime warranty but if the replacements will also be junk then I don't see the value in swapping them out. Rust in my eyes for no reason.
      I've had the hop in the Panthers too, but generally only on extremely aggressive and repeated bumps, like a few potholes spaced just right relative to the wheelbase that the car can't settle again between bumps. The Ranger will get shaky after just a single significant bump. But the lack of sway bar, soft springs, and low-functioning shocks all come together to multiply the effect.
      Current driver: 91
      | 88 TC | 91 GM
      | Junkyards
        I once found a Gen 1 Ranger in the junkyard that was an old U-Haul truck. Huge front and rear sway bars. Just in case you come across one...
          Ranger Marti report:
          Current driver: 91
          | 88 TC | 91 GM
          | Junkyards
            WHoever ordered that had priorities; I don't need no stinkin' radio! Give me power brakes though.
              Its funny that no radio was an option. What was standard, just AM/FM ? or would that have been AM-only? There is actually an electronic AM-only radio. I have no idea why this exists, but I have docs for it in my radio service manuals.
                Putter Project has no radio or air conditioning. Strictly a work truck. I guess there was no playing around in the early '80s LOL
                  28 days late...apparently the 2.0 wasn’t the only slow thing with that truck.
                    Probably just AM. I've seen GMT400 trucks like I've got in stripper form with AM only radios, knobs and all. I went to nab one from a junkyard several months ago for posterity but the shit in the wheelbarrow shifted and killed it..
                      I have been in an early 80s Club Wagon (which I suppose is probably an extended length E-250 with the passenger goodies) which had an AM-only radio with electronic tuning. I also have no idea why it exists. That was probably base for a Ranger as well. The guy did put in a radio, and he was the original owner, and the one he put in was period correct for the truck...it's entirely possible he reasoned that the added cost to upgrade to FM was more than the off-the-shelf price to buy an aftermarket unit.
                      Newest update for the Ranger is a fun one. Pulled the trans today. It seems to need an input shaft bearing (mild noise when off the clutch pedal, and it does wiggle slightly), and I'm going to have my buddy with the machine shop try to resolve the fluid loss issues out the extension housing. I like to run Redline MT-90 which is not really cheap, and this trans likes to piss a little everywhere it goes, so hopefully I can get that taken care of. Replacing the seal did nothing for it previously.
                      I would probably consider swapping to a M5OD, but there are some dumb things involved with that, like finding the correct clutch line (TK5 slave input is clocked around 11:00 from the back, while M5OD is from about 9:00, which is also why the M5OD is notoriously awful to bleed the clutch on), and the driveshaft length might be different, and as silly as it is I don't like the M5OD shift levers.
                      Current driver: 91
                      | 88 TC | 91 GM
                      | Junkyards
                        Make sure the yoke on the driveshaft is in good shape. If that has a groove worn in it, the seal won't actually seal. Worth checking the output shaft bushing too.
                        I am sort of curious what the cost-add for AM radio vs AM/FM was over no radio. Probably is more than a basic aftermarket radio and speaker package would have cost, and its not like the OE stereo was anything impressive.
                          AM radio as base equipment existed so they could charge a premium for FM and above.
                            The '89 Aerostar XL my parents bought new had an AM radio with electronic tuning. I miss the old days.
                            —John
                            1985 Ford F-150 XLT Lariat
                              I get the upgrade thing, but I don't get why they paid to develop a digital one when they had a conventional analog AM already.
