Most are probably aware of my issues with the steering column in my 85 TC.
To recap when changing the rag joint (or 'donut' or 'steering shaft coupler' or as Ford says 'flange and insulator assembly') I managed to pull the shaft partway out of the steering column.
I tapped it back in, and it works, no play in the wheel etc but there is a rattle in the column when I hit bumps etc. My neighbor again: 'Turn up the radio'
I've searched but found little info on the interior of a column, so thought this old part changing hack might actually be of some use.
I'm going to disconnect the steering shaft, either at the joint just above the ujoint in front of the firewall (if it'll come apart) or if neccessary at the rag joint, and try to monkey/worry it in, maybe I'll get lucky.
As the only luck I've had lately is the not good variety I'm researching info. Curious anyway.
Anyway, info. Views of the column with parts list, tilt 1st, then no tilt (the tilt drawings seem to reference the nontilt btw):
coltilt1.pdf
coltilt2.pdf
coltil3.pdf
colfix1.pdf
colfix2.pdf
colfix3.pdf
Sorry for having to rotate view on some of them, I have no way to manipulate pdfs.
On mine, on 'coltil2' parts 31 and 32 are loose. I assume 31 is supposed to go into 25, then 32 gets pushed up in there to hold it.
I also think the rattle is coming from 35. I might have knocked them loose. Weather permitting I'll find out soon.
Pete
coltilt1.pdf
coltilt2.pdf
coltil3.pdf
colfix1.pdf
colfix2.pdf
colfix3.pdf
Pete
