I have a set of Lincoln logs. I'm gonna put them on my 88 MGM i just have one question do they need exhaust gasket because when I took them off I don't remember seeing and on the 90 tc they came off from
Lincoln logs
I had planned on using gaskets when I was going to swap them onto my '85 vic. I can't imagine it would be a bad idea to use gaskets if they originally used them or not.
Also, I had heads that I thought had no gaskets on them, but I missed on the casual glance because they get all squashed and gunky. Maybe you were so thrilled and excited by your find that you overlooked the gaskets? I know that could happen to me!************************************************** ******************************
1997 Crown Vic - Mostly rust free, moderate mileage. On the road... but far from perfect. **SOLD**
1985 Crown Vic in 2-Tone Blue **SOLD**
http://automophiliac.blogspot.ca/
If they are like the stock manifolds there there is no gasket. For the stock manifolds I was told it had something to do with cast iron manifolds bolting to cast iron heads but I never asked why the metal used made a difference.Vic
Related question about these as I have a set I'll be installing as well:
Is there a direct fit stud available on the market or is it best to drill the threads out and just use normal bolts?
You mean the studs that the cats/down pipe mount to?
If Lincoln Logs use the same studs as a box, order studs for a 1980 MGM (DORMAN 03099, Size: 7/16"-14 x 2-1/4"). You'll need 2 since they come in packs of 3 studs.
DO NOT order DORMAN 03129, Size: M12-1.75 x 62mm, these DO NOT fit box manifolds.Vic
Originally posted by VicCrownVic View PostYou mean the studs that the cats/down pipe mount to?
Interesting you mentioned those, I already have some 03129s on hand and know they don't fit the '90 Lincoln ones from experience.
I'll see if I can find 03099 in stock locally and check fitment with them. They do seem a bit short but I also haven't tried to mock it up yet so maybe it's plenty of stud, I don't know.
So the Lincoln Logs probably use the same studs as box manifolds. The 03099s are what I have on The Ice Car, there's plenty of stud to get the nut on. Once tightened there's enough room to get another nut on the stud, probably no more than that but they're plenty long enough to do the job.Vic
Holy cow shit, the stockers weigh 17lbs a pop? Nasty. I've never seen Linkin' Logs up close, they honestly don't look so bad. I was thinking of doing BBK headers if I went through with the HO swap on my TC but I might re think that now as those aren't half bad and would save me from having to re work my exhaust again.1985 LTD Crown Victoria - SOLD
I would clean the cylinder heads and manifold flanges very well. I would use *good* gaskets, and I always coat both sides of the gasket evenly with a piss coat of high temp RTV. I despise exhaust leaks.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostI would clean the cylinder heads and manifold flanges very well. I would use *good* gaskets, and I always coat both sides of the gasket evenly with a piss coat of high temp RTV. I despise exhaust leaks.1993 Ford F-150 Flareside - July 2010 - August 2013
2004 Ford Mustang - September 2013 - February 2018
1987 Mercury Colony Park GS - August 2015 - Present
2018 VW Golf GTI - February 2018-February 2021 (was a lease)
2003 EZGO TXT - March 2015 - May 2019 (it's road legal!)
2019 VW Golf Alltrack company provided April 2019 - Present
2012 Fiat 500 5 speed - January 2021-Present
2003 Audi A6 Allroad 6 speed July 2021-Present
I'll see if I can find 03099 in stock locally and check fitment with them. They do seem a bit short but I also haven't tried to mock it up yet so maybe it's plenty of stud, I don't know.Vic
I have cheap ones on my car, after a few years of monthly bolt re-torquing and quarterly gasket replacements I had them milled flat and have not had problems in years. Probably could have just gotten a new set of good ones for all the headaches these put me through and not had any problems.86 Lincoln Town Car (Galactica).
